Torque Request
Torque Request
Postby Victorgarage on Sat Feb 27, 2021 9:36 pm
Hello i am asking from a reflash software like romraider or openflash point of view.
There are components to adjust or fill in table for torque request againts torque calculated from feal engine
Basically like when we suddenly flooring the pedal.. the information then passed to the auto trans controller to shift down the gear.
Vise versa when to shift up under a very light load.
Ok so my question is.. in m150 which is in my car is a plug in model for GT86.. the com is through CAN
But somehow the Trans Controller is receiving wrong data. So it wont change gear up and down like when i use with the stock ecu.
Is there anyway so deal with theese please.
Someone please help.. since this has given me a headache for weeks.
Victorgarage
Re: Torque Request
Postby David Ferguson on Sun Feb 28, 2021 2:50 pm
Are you using Firmware Version 1.08.0003 {January 2017] ? According to the data sheet found here:
https://www.motec.com.au/filedownload.p ... docid=4502
that version added support for Automatic Transmission Models.
Re: Torque Request
Postby Victorgarage on Mon Mar 01, 2021 12:45 am
viewtopic.php?f=59&t=4710
Please check my post there..
Im pretty helpless now. Since i am lost somewhere and no help till now.
Victorgarage
Re: Torque Request
Postby David Ferguson on Mon Mar 01, 2021 1:54 am
Well, Are you running the latest firmware Package for the Automatic Transmission? It looks like v1.11.18 is available for different model years from this link:
https://moteconline.motec.com.au/Packag ... geNumber=3
What model year is your car? I'm asking so I can look at the correct package.
Your MoTeC dealer should be providing support. Where are you located, and who was the dealer?
In M1 Tune, you should use one of the "All Calibrate" worksheets to verify that Toyota 86 Transmission Type is set to Automatic.
Re: Torque Request
Postby Victorgarage on Mon Mar 01, 2021 3:48 pm
mine is 2015 AT
with plug in harness A sir
im In Timor Leste
no dealer yet here sir
Victorgarage
Re: Torque Request
Postby Victorgarage on Mon Mar 01, 2021 3:49 pm
David Ferguson wrote:Well, Are you running the latest firmware Package for the Automatic Transmission? It looks like v1.11.18 is available for different model years from this link:
and yes i did use the v5 firmware
which is being updated by Nathan through email
but havent heard from him for weeks now
Victorgarage
