DBW feedforward and P & I controls
Postby SteveC on Wed Feb 03, 2021 3:51 pm
Questions on DBW feedforward.
1. Is it best to configure the Feedforward table to just below the Target Aim Idle ?
the idle aim main is set to 1500 cold and 1250 warm so the feed forward table has 3 entries for rpm 1100 1250 and 1500
I have set this at running temps to be as close as possible but it fluctuates around the target - is this normal for dbw and Big CAMS.
2. what do configure next - the idle ignition timing limit advance control proportional and integral gain ??
or
Idle Mass flow Integral and proportional gain (I before P in the help)
Now i have played with the idle ignition timing limit advance control and got the idle close to idle aim main and its good.
If i blip the throttle i get hugh oscillation to stall with 0 entries are in the Idle Mass flow gains and no matter what setting i use it never goes away. so I at 160 and P and 0 as a start as per the help.
Any help would be good.
SteveC
Re: DBW feedforward and P & I controls
Postby Stephen Dean on Wed Feb 03, 2021 5:03 pm
Can you send the logging from this to support @ motec.com.au and I'll have a look at it for you.
Usually if the FF table is correct, there is minimal amounts of P & I needed (most vehicles that I have done just use the base settings).
The FF table usually has a larger number of cells in it than you have described.
Postby SteveC on Wed Feb 03, 2021 5:45 pm
Motec idle 2.png (6.91 KiB) Viewed 5049 times
Idle Aim
Motec idle 1.png (7.42 KiB) Viewed 5049 times
Ramp rate
Feed Forward
Motec idle 3.png (13.97 KiB) Viewed 5049 times
More than 3 cells
SteveC
Postby SteveC on Wed Feb 03, 2021 5:50 pm
I will send over the config and log file shortly ;)
SteveC
Users browsing this forum: No registered users and 35 guests
