No boost control
Last season i had full closed loop boost control. This season i added a separate boost sensor. I calibrated it correctly and now have a channel for boost pressure and also boost pressure sensor. Last season with just the map sensor the boost pressure read as it should- 0 psi with key on eng off. Now this year the boost sensor channel reads the same at 0 psi key on eng off but my boost pressure channel reads -14.7psi.
So now when i get into boost the system does not activate. It seems the m1 is using the boost pressure channel instead of the boost pressure sensor channel. On log i i can only get 8psi (gate spring pressure) becuase the boost system does not actuate. The ecu sees -6psi when the boost sensor sees 8psi so it doesnt hit the 3psi needed to activate the system. Any ideas? If i go back to just the boost pressure channel it works as it should.
2016 m1 plug in system for the skidoo xs1200
