Bosch Throttle Servo Calibration 0 280 750 473 82mm
Thu Sep 10, 2020 12:07 pm
by ajwithers
Does anyone know if the calibration for the Bosch 82mm 0 280 750 101.1.0 is the same calibration used for the Porsche GT3 TB (Porsche Part # 997.605.116.01 Bosch Part # 0 280 750 473). The connector in the help file appears to be the same with the same pinout information.
Thanks in advance,
Aaron
Re: Bosch Throttle Servo Calibration 0 280 750 473 82mm
Thu Sep 10, 2020 1:32 pm
by adrian
You shouldn't ever use the calibration for one servo for another. We have a calibration for 0 280 750 473 it just hasn't been uploaded into our system yet (so its not in the drop down in M1 Tune).
Send an email to
support@motec.com.au and I'll send you the cal file.
Thu Sep 17, 2020 12:03 pm
by ajwithers
Anyone have a good throttle area configuration for the Bosch 82mm throttle bodies?
Thu Sep 17, 2020 2:34 pm
The default provided with the GP package should work well for that throttle. Here is a copy in case you want to compare:
