Bosch Throttle Servo Calibration 0 280 750 473 82mm
Postby ajwithers on Thu Sep 10, 2020 12:07 pm
Does anyone know if the calibration for the Bosch 82mm 0 280 750 101.1.0 is the same calibration used for the Porsche GT3 TB (Porsche Part # 997.605.116.01 Bosch Part # 0 280 750 473). The connector in the help file appears to be the same with the same pinout information.
Thanks in advance,
Aaron
ajwithers
Re: Bosch Throttle Servo Calibration 0 280 750 473 82mm
Postby adrian on Thu Sep 10, 2020 1:32 pm
You shouldn't ever use the calibration for one servo for another. We have a calibration for 0 280 750 473 it just hasn't been uploaded into our system yet (so its not in the drop down in M1 Tune).
Send an email to support@motec.com.au and I'll send you the cal file.
Postby ajwithers on Fri Sep 11, 2020 12:17 pm
adrian wrote:You shouldn't ever use the calibration for one servo for another. We have a calibration for 0 280 750 473 it just hasn't been uploaded into our system yet (so its not in the drop down in M1 Tune).
Thank you!!!
ajwithers
Postby ajwithers on Thu Sep 17, 2020 12:03 pm
Anyone have a good throttle area configuration for the Bosch 82mm throttle bodies?
ajwithers
Postby David Ferguson on Thu Sep 17, 2020 2:34 pm
The default provided with the GP package should work well for that throttle. Here is a copy in case you want to compare:
Throttle Area.zip
Standard GP Throttle Area table
(958 Bytes) Downloaded 916 times
