Pump output switched off Oil Temp - GPA M150
I want to install a booster pump inline with my water-oil cooling system, but I haven't found an option that can be driven from oil temp in the GPA package.
I would like the pump to be switched (low side) based on oil temp, to give me a little extra cooling capacity as the oil can get to 120*C if I am in traffic for a few laps. Others with similar cars have done similar but usually they just have it as a switch on the dash they can use if the oil temp is getting hot, but I don't want to have to think about that... and I have an ecu that can control this for me.
The GPA package has options for differential and transmission pumps, driven off their respective sensors.
From the looks of it, I can assign the transmission temp sensor as the same input (analogue voltage input 6) as the oil temp input and it'll just use the oil temp sensor, then I can just define the pump parameters which will switch the pump on and off.
Has any one else done something similar? Or is there another way I could do this?
