Reverse switch over CAN
Is there a way to transmit the gear box reverse switch signal over CAN bus? The clutch and neutral switch is part of the PDM can bus protocol, but I cannot find the reverse switch anywhere.
In a Porsche the reverse switch is just next to the engine and it would be easiest to pull it into the ECU together with the rest of the harness rather than to pull it to the PDM.
Thanks!
Thanks!
