Data sets over can
Data sets over can
Postby wakeboardcraze on Wed Sep 02, 2020 12:15 am
Using a m130 ecu with Yamaha waverunner package. I’m attempting to get my BTI dash seeing the correct data set to display map, rpm, temp, aft, boost, fuel pressure and oil pressure. Fuel pressure and oil pressure are added in sensors and everything is properly viewing on M1 tune from my laptop. My BTI gauge seems to be reading AFR and Rpm correctly, fuel pressure is reading 600kpa and map is 1000kpa and the others not even reading anything. Anyone happen to know if there is a different data set sent vs the gpa/gpr packages?
wakeboardcraze
