Running M142 ECU in a 24V environment
is it possible to run the M142 ECU with 24V supply voltage?
Will the voltage regulators inside the ECU lasts this voltage level?
Sensors are supplied by internal 5V/6.3V - so probably not an issue. Same with the low-side outputs as max. voltage is specified with 40/60V here, I think.
Driven DI injectors are of 24V type (inductive). Boost voltage of 90V should be still available with 24V supply, output stage controls current --> so could work anymore, if current level meet the requirements of the injector,
But what's with the full bridge driver to run a DBW unit? Will this work? Is it possible to use a 12V DBW unit?
thanks in advance, Klaus.
