Fuel long term trim
Is it possible to use an fuel long term trim like the haltech elite 2500 have?
What it does is that it takes the lambda correction offset and adds adjustment in % in an separate long term trim map, to show the user how off the map is (it applies the adjustment in real time all in the background in the ecu).
Then the user can apply this permanently to the base fuel map later on if its needed.
Is this possible?
Is this possible?
