Racegrade SSD3 - M150
Postby ajwithers on Sun Aug 09, 2020 2:29 pm
I am going to use the Racegrade SSD3 to PWM control my fans.
As I read the instructions I would use a Ignition/EFI B+ for the “Active High” input signal and then use an available LS output from the M150 to send a duty cycle signal to the “Active Low” input.
Has anyone configured one of these and can confirm?
http://www.racegrade.com/downloads/RG_S ... Driver.pdf
ajwithers
Re: Racegrade SSD3 - M150
Postby Stephen Dean on Tue Aug 11, 2020 10:33 am
I would have the high side power for the Active High as a switched supply,that is only powered when the M1 is powered, otherwise your setup is correct.
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
