How are You?
I wanted to know if it is normal that it takes more than 20 min to download the data from an M142, (level 1 datalogger calibration, std) approximately 1 hour of data recording.
THANKS, REGARDS!
David Ferguson wrote:Does your laptop have a direct Ethernet connection, or are you trying to use a USB Ethernet Adapter? When you tried another laptop was it using the same Ethernet adapter?
I would be skeptical that a USB Ethernet adapter could keep up with 100 Mbit/s Ethernet (of course one could be designed, but often to cut corners, you might find it only does 10 Mbit/s. While USB 2.0 was has a theoretical bandwidth of 480 Mbits/s, this bandwidth is shared by all the devices on the USB bus. So the performance could be slowed by devices like a USB mouse, keyboards, etc.
What does Windows report for the Ethernet speed? 100 Mbit?
