M130 GPR Motorcycle
Looking to upgrade to M130 ECU, while some base packages for the 130 are available on Motec Online I cannot find the M1 130 Motorcycle base package. Is it possible to view a copy to see its capabilities.
I see from the spec sheets that the knock sensor inputs have been re purposed to suspension potentiometer inputs.
Are these set that way in this build, or can knock sensors be used to set base timing & later the suspension pots be fitted for the track.
Thanks,
Michael
Thanks,
Michael
