M130 k20/k24 set up
Im new to motec. Still learning my where abouts threw software. While playing with it it seemed easy. As I started to make my package. Started to get a little confused.
I need help with sensors set up. For rev sync I found k20 which should be the same as k24. I figured the exhaust cam is the engine syncronization input.
For sensor critical:
Coolant temp for k24a2 I'm unsure of low and high volts for Honda sensor
Inlet air temp for k20a2. I'm unsure of low and high volts for Honda sensor as well
For inlet manifold pressure (map) unsure of low and high volts as well. I'm using a hondata 7bar map. All they can tell me is volts at atmosphere and Scalar: 1582
Offset: -351
For ignition configuration
Ignition coil calibration Im unsure of specs for k20/24 data.
Confused on what would be categorized digital and analogue inputs. I know crank, cams, and flex sensor would be digital. So would tps,map, boost solenoid, gear sensor,level sensor all be analogue?
For ecu I/O
Inlet cam bank 1 output should is the vtc solenoid. I should be ok running a half bridge on that solenoid? It just a oil control valve basically.
0volts threw out the software means like ground?
Are the outputs all 12v+ or can be made to be ground or 0volts
Injector outputs are ground/0volts?
Offset: -351
For ecu I/O
