Idle speed (vs Volts!)
Hi
Today's weird question...
Is there any way to get the idle speed to increase if battery volts drops below a certain level?
The best I have come up with is a "fake" air con input from a PDM or CDL (if battery volts < xV then turn on "air con", and then use the aircon increase idle parameter).
The reason for this is the car has a "race" alternator that cuts in at pretty high RPM (and I can't change the gearing because of the alternators upper RPM) and I can't fit a more sensible alternator (chassis/water pump outlet/dry sump pump/wishbones/driveshaft etc in the way!).
Thanks in advance.
Thanks in advance.
