M130 CAN messaging to EPS
Hello, I am doing a complete rewire on a car which did not have electric power steering, and will be installing the electric power steering unit, complete with power steer ECU, from a Toyota 86 in to it. I plan on using an M130 ECU. Is there a way for me to send the CAN signals required to the Power Steering ECU using the GPR package for the ECU, or will I need the 86 package? The only issue with that is, nothing else in the car is from an 86. Speed signal will be coming via vehicle speed sensor in gearbox.
Secondly, can auxillery outputs on the M130 be directly controlled (on/off) via conditions dictated by a PDM30 connected via CAN? I've had a look in M1 tune and the only thing I've been able to find to set conditions for an output are things like rpm or race time.
