Bosch wiper motor och LIN with motec- never mind :D
PostPosted: Sun Oct 13, 2019 8:50 am
by karel021
*was to fast to post this question.
post can be removed.
Hey guys is there a way to utilize the LIN communication with the Bosch Direct actuator wiper motor to a motec ?
http://www.bosch-motorsport.de/content/ ... =50966027/
Re: Bosch wiper motor och LIN with motec ?
PostPosted: Sun Oct 13, 2019 9:24 am
by karel021
ok i was a bit to fast on this post.
Skärmavbild 2019-10-13 kl. 00.23.04.png (50.34 KiB) Viewed 7387 times
i guess there isnt any problem to run the bosch unit then :)
Re: Bosch wiper motor och LIN with motec- never mind :D
PostPosted: Mon Oct 14, 2019 3:42 am
by Herrubermensch
Can also run the non-LIN version using outputs from the dash. There is a thread in the PDM section about it.
--Peter
PostPosted: Thu Oct 17, 2019 1:49 am
by karel021
Herrubermensch wrote:Can also run the non-LIN version using outputs from the dash. There is a thread in the PDM section about it.
--Peter
Gotcha.
but i saw that the gprp package has the settings for the Linbus version so i will go with that :)
