Applying 12V signal to narrowband lambda input
Hi there
I have an application where I need to measure a signal that switches between 0V and battery voltage depending on the state of a sensor (detects immersion in water). I have used a narrowband lambda input for this, which has a maximum A/D range of 6.098V - is it going to cause any issues if this channel sees 14V? The M1 ECU Hardware document specifies the channel has a no-damage range from -30 to +35V, but I want to be sure that other readings wont be affected by going over-voltage on the A/D converter.
I can use a voltage divider or zener diode to bring it into the range of the A/D, but I don't want to add one if it's not necessary. I have no other spare inputs or outputs that I can use.
