Fuel level signal query and alternator light
Postby Bigade49 on Tue Aug 20, 2019 7:21 am
I have intank lift pumps and fuel level switch to wire into an M150.
I'm not sure how to wire in E and F? which type of channel etc?
This is the intank fuel connector pinouts I've been given:
A +ve Two left hand low-pressure pumps
B -ve Two left hand low-pressure pumps
C +ve Two right hand low-pressure pumps
D -ve Two right hand low-pressure pumps
E Float switch contact closed on low-fuel level
F Float switch
I'd like to measure fuel level and low fuel on the D153 dash if possible.
TIA
Ade
Bigade49
Re: Fuel level signal query and alternator light
Postby David Ferguson on Tue Aug 20, 2019 9:59 am
Is the float switch a simple switch, or does it provide a variable resistance output? If so, what is the range of resistance from full to empty (or the point at which it closes completely)?
