Half Throttle Pedal Tracking Fault
Postby Leo Huang on Thu Jul 25, 2019 4:37 am
I found that we were causing pedal tracking fault when we were half-throttle, But throttle pedal sensor diagnostic is OK when throttle pedal is close to 0% and close to 100%.
Below is time graph of main sensor and tracking sensor.
The voltage looks correct but there was a problem when converting to a percentage
Thanks a lot !!!
throttle pedal fault.PNG (671.29 KiB) Viewed 4261 times
Leo Huang
Re: Half Throttle Pedal Tracking Fault
Postby PEI330Ci on Fri Aug 02, 2019 4:51 pm
Leo Huang wrote:Hi,
Thanks a lot !!!
It looks like you have some kind of delay between the signals.
Can you show your throttle pedal setup screen?
PEI330Ci
