1) Does motec consider launch control the same as rolling anti lag? Reason for ask is can I use one AV to turn either one (if car is rolling, then rolling anti lag.. if its not, then launch control). since its basically the same thing. Or do i need 2 separate AV inputs to trigger each mode?
1a) When active, can I control an output ( i want to control a solenoid that controls clutch release speed) only if I am stopped and in launch mode
2) How can I determine what the CAN address for ethanol content is? I am using 0x640 to communicate to my AIM dash, but it seems Eth% is not part of it. AIM said if I can tell them the parameters they can add it.
3) This is in a Porsche Cayman with a LSV8. The wheel speeds are clearly reported by the ECU canbus, but from what I understand without developing my own firmware I can't access those. AIM said they MIGHT be able to get that data but nothing yet. I know its bad news to tap into the wheel speeds before the ABS, so I assume my only option is to fit a tone ring to a rear CV, and also one of the front wheels?
