Failed To Update Calibration
PostPosted: Tue Apr 23, 2019 8:44 pm
by Loqy
Hi everyone,
I'm new with the M1 ecu.
When I 'Check for Updates' all the updates are :
- Systems (2)
- Calibrations
- M1 Application
See attached picture :
WhatsApp Image 2019-04-23 at 16.22.37.jpeg (30.97 KiB) Viewed 9245 times
All the files has been successfully updated except the Calibrations
WhatsApp Image 2019-04-23 at 16.14.07.jpeg (80.37 KiB) Viewed 9245 times
Here are the few questions that I'm holding :
- Is that Windows problem ? I already turn off Firewall & Antivirus, but still not working.
- Is it M1 software problem ? Because I already use other laptop but still not working.
Any post will be highly appreciate.
Re: Failed To Update Calibration
PostPosted: Wed Apr 24, 2019 11:03 am
by Stephen Dean
I see that M1 Tune is also prompting for you to update to 01.04.0.200, can you please do this and then retry the Check for Updates.
Also, do you have M1 Build installed?
PostPosted: Thu Jun 27, 2019 11:38 pm
by Donovan CR6
Mine is doing the same, can't figure it out :cry:
PostPosted: Fri Jun 28, 2019 10:43 am
by Stephen Dean
If you have M1 Build installed can you ensure that it is the latest version as there is a difference between the location that M1 Build and M1Tune stores the calibration files. This was bought on by Microsoft making a change to the way that file permissions are done in the user profiles.
The files are stored in C:\Users\UserName\AppData\Local\MoTeC\Calibrations, if you go into this directory (as the AppData directory is hidden you will need to turn on the "show hidden files and folders" option in File Explorer) and delete all of the files and folders in it, the next time that M1 Tune is restarted it will do a check for updates and reprocess the retrieve.
PostPosted: Thu Sep 19, 2019 7:45 pm
by Loqy
Already upgrade to M1 Tune 1.4.0.200 and M1 Build 01.04.00.0185
But still not working
I'll try the other way that you've explained.
Thank you, really appreciate.
