Crank reference position
Hi
Just confirming to make sure I have read the help correctly.
I am on a 60-2 crank trigger pattern (machined into the flywheel) triggering a hall effect sensor. The leading edge of the first tooth after the gap is at 60 degrees AFTER top dead center.
So, do I enter -60 as the engine speed reference offset, with trigger on rising edge?
Thanks in advance
Thanks in advance
