Crank reference position
Postby greenamex2 on Mon Apr 22, 2019 8:09 am
Hi
Just confirming to make sure I have read the help correctly.
I am on a 60-2 crank trigger pattern (machined into the flywheel) triggering a hall effect sensor. The leading edge of the first tooth after the gap is at 60 degrees AFTER top dead center.
So, do I enter -60 as the engine speed reference offset, with trigger on rising edge?
Thanks in advance
greenamex2
Re: Crank reference position
Postby greenamex2 on Tue May 07, 2019 7:43 pm
Can anybody confirm?
greenamex2
Postby Stephen Dean on Wed May 08, 2019 11:22 am
That is correct.
M1 Reference Offset Missed Tooth.pdf
(358.18 KiB) Downloaded 1067 times
Postby greenamex2 on Thu May 09, 2019 7:22 pm
SDean wrote:That is correct.
Thanks for confirming Stephen. Didn't want to spend hours trying to get the engine to start for the first time on a misunderstanding...it's going to be nerve racking enough as it is!
greenamex2
