Engine Sync Position Diagnostics says Invalid Camshaft
Trying to start Toyota 3S-GE engine with M150 equipped with GPR project sourced package as a first start. In the future there will be M130 highly likely with GPR package. Engine is used without vvti system as class rules do not allow them.
Reference sensor is oem with inductive sensor, 36-2 teeth. Sync sensor is oem inductive sensor reading exhaust cam 4-1 teeth. Ref goes to UDig1 input, Sync goes to Udig2. Inlet cam sensor is not used atm. Engine Speed Reference Mode is 37 ie. Toyota 2ZZ. The description says that all camshafts are used for synchronisation. Tried to configure Cam Inlet and/or Exh sensor resources to various UDig inputs.
When checked with Capture Inputs...-function both ref and sync signals are just as described. Parameter "Engine Synchronisation Position Diagnostic" says "Camshaft Invalid". When injector or ignition coil outputs are tested with at least some rpm (over 500rpm) the message says Ok. When rotated with starter motor "Engine Speed Reference State" goes to "Pattern Lock" indicating that crank sensor is read and decoded correctly. What is wrong or missing? How this kind of engine should be wired and setup if all oem camshaft functions are used?
I'm sure that this could be made to work by grinding two extra cam teeth away but rather not to destroy customers camshafts.
Thanks!
Thanks!
