M150 Injector wiring.
Postby sleeper on Sat Jan 26, 2019 10:26 pm
Hi.
Can you use the P&H injector outputs to run high imp injectors as saturated by just setting it up as saturated in setup? ( changing from low imp to high imp injectors, and dont want to rewire if needed. )
Thanks.
sleeper
Re: M150 Injector wiring.
Postby stevieturbo on Sun Jan 27, 2019 2:01 am
Yes, it's just the software/instructions etc are poorly worded and laid out.
viewtopic.php?f=53&t=4129
Postby greenamex2 on Sun Jan 27, 2019 7:05 am
As Stevie said, yes you can.
And you can use spare ignition outputs as well.
Hence you can run a six cylinder with coil on plug and sequential upper and lower injectors on an M130. Just.
greenamex2
Postby sleeper on Mon Jan 28, 2019 1:57 am
Thank you for the help.
sleeper
