M130 Ignition Output Configuration
Postby LouDen Motorsport on Thu Jan 24, 2019 4:23 pm
I'm back, with a question very similar to my last :)
Previously I asked about injectors. This time it's the coilpacks I need to re-configure. We're using the OEM 3 pin Bosch coilpacks, so I'm fairly sure (really happy to be wrong here) that it's not a low-side switching system.
Is there a setup page to allow me to change the ignition output "style" ?
Thanks, in anticipation.
LouDen Motorsport
Re: M130 Ignition Output Configuration
Postby Stephen Dean on Fri Jan 25, 2019 8:52 am
If you have the part numbers for the coils, I can look and see if we have calibrated these and confirm the manner that they are driven.
Postby LouDen Motorsport on Sat Jan 26, 2019 7:25 pm
Hi Stephen. The part# for these coils is BOSCH 0 221 504 456 aka BERU 0 040 100 428
It's fitted to the Alfa Romeo 3.2V6 as found in the 147GTA's
If you think it would be advisable I can pack up an injector and a coilpack and send them down for calibration.
LouDen Motorsport
Postby Stephen Dean on Tue Jan 29, 2019 4:06 pm
We have calibrated these coils, I have attached the information or you.
Bosch 0 221 504 456.xls
(93 KiB) Downloaded 997 times
