GP V1.10 issue
Wed Dec 05, 2018 8:39 am
by greenamex2
- Capture.JPG (55.68 KiB) Viewed 10031 times
Any idea how to get rid of this?
Re: GP V1.10 issue
Wed Dec 05, 2018 8:44 am
by greenamex2
Config (so far, engine not run yet...not even finished sticking it together yet...still learning!)
Re: GP V1.10 issue
Wed Dec 05, 2018 9:33 am
I would just enter a valid value for a LIN baud rate. I know it's not needed (since there is no LIN bus on the M130), but you asked how to fix that.
Re: GP V1.10 issue
Wed Dec 05, 2018 9:48 am
Thanks for reporting this, I have logged it as an issue for the developers to investigate. It will not cause any operational issues for the M130, other than the error shown.
Hi David, That will not fix it, it needs a code change.
Re: GP V1.10 issue
Wed Dec 05, 2018 12:02 pm
by rntechnologies
I haven't had a proper look at 1.10 yet, however this is the same issue as the rs232 error messages appearing on the M130 with the older versions.
The root of the issue is that the firmware contains the modules for LIN and RS232 whilst the hardware does not have this capability in the M130.
The fix as Stephen mentioned is to actually remove these modules from the package or adding code to allow them to be disabled completely.
Re: GP V1.10 issue
Thu Dec 06, 2018 9:13 pm
by greenamex2
Thanks one and all.
Not a big issue for me at the moment...too busy making engine mounts!
Re: GP V1.10 issue
Thu Jan 31, 2019 5:12 am
by greenamex2
Sorted. The firmware issue NOT the engine mounts!
