system version update affect firmware?
Postby CarloL on Mon Oct 08, 2018 12:16 am
Hi
Quick one, would keeping the ECU System version up-to-date ; have an impact on the firmware installed?
Can you step back to an older ECU System version, I do not see an option
CarloL
Re: system version update affect firmware?
Postby Stephen Dean on Mon Oct 08, 2018 8:44 am
Hi Carlo,
It is recommended to keep the firmware up to date, as we do minor bug fixes and updates with the firmware releases.
With the newer versions of M1 Tune, there is the option to go back to an earlier system file if needed using the File | Override ECU System Version... function.
