Set up cyclic idle
Wed Oct 03, 2018 3:48 pm
by junnan yue
Hi guys
Interesting with how to set up cyclic idle on MoTeC M1 ecu with GPR package.
Cyclic idle sound so good!!!
Re: Set up cyclic idle
Wed Oct 03, 2018 5:16 pm
You can do it using the Anti Lag settings, having a large throttle opening aim and a lot of ignition cut and retard to maintain the engine speed that is set in the Anti Lag Engine Speed Limit, as well as adding in fuel.
Wed Oct 03, 2018 8:10 pm
by junnan yue
Thanks a lot SDean! I will try that.
Thu Oct 04, 2018 5:35 pm
by junnan yue
Hi SDean
Can I have an example file that I can look at?
When Antilag State is Disabled is not using the Antilag Throttle aim Main table and Ignition Cut table at all.
What I should do or did I miss something?
Fri Oct 05, 2018 3:26 pm
by junnan yue
Anyone?
