Set up cyclic idle
Set up cyclic idle
Postby junnan yue on Wed Oct 03, 2018 3:48 pm
Hi guys
Interesting with how to set up cyclic idle on MoTeC M1 ecu with GPR package.
Cyclic idle sound so good!!!
junnan yue
Re: Set up cyclic idle
Postby Stephen Dean on Wed Oct 03, 2018 5:16 pm
You can do it using the Anti Lag settings, having a large throttle opening aim and a lot of ignition cut and retard to maintain the engine speed that is set in the Anti Lag Engine Speed Limit, as well as adding in fuel.
Postby junnan yue on Wed Oct 03, 2018 8:10 pm
Thanks a lot SDean! I will try that.
junnan yue
Postby junnan yue on Thu Oct 04, 2018 5:35 pm
Hi SDean
Can I have an example file that I can look at?
When Antilag State is Disabled is not using the Antilag Throttle aim Main table and Ignition Cut table at all.
What I should do or did I miss something?
junnan yue
Postby junnan yue on Fri Oct 05, 2018 3:26 pm
Anyone?
junnan yue
