PWM TPS
Hi
Not sure if this really an enhancement request but thought I would highlight it.
For a PWM ouptut throttle position sensor the current GPA firmware is fixed at a "100%" value of 5ms. Assuming using the full range of a cycle this equates to a frequency of 200Hz.
So far most of the throttle position sensors I have found are well in excess of this. For example the Curtis Wright sensorss are 244Hz (OK, this one is pretty close!), 500Hz and 1000Hz and the Vishay 981 sensor is 1000Hz.
For example, if you use a 1000Hz the maximum pulse duration would be 1ms, or one fifth of the 5ms assumed for 100% Add in the fact that you are incredible unlikely to even hit 1ms, or have 0ms as 0% throttle opening, you are possibly beginning to restrict resolution.
In short...any chance of making the 100% duration configurable? Would improve compatibility with more sensors.
