Closed Loop Fuel setup on M130
I have a M130 ECU which is set up with closed loop fueling on a V6 engine. There are two lambda sensor connected to a MoTeC LTCD providing the AF values to the ECU.
I am questioning whether the fuel trim are individual for the two cylinder banks based on the respective AF measurement, or if the two AF measurements are averaged and providing a common fuel trim for all cylinders.
