Aprilia v4 ref/sync
Sat Aug 25, 2018 11:03 am
by phatbob
has anyone sorted out the ref/sync for an aprilia v4 (rsv4/tuono) for M1 ? would like to start on a project but haven't seen any reference to the above...
-P
Re: Aprilia v4 ref/sync
Sat Aug 25, 2018 12:01 pm
by David Ferguson
Have you done an input capture to see what the pattern looks like? Might be one of the generic ones, but you won't know unless you check.
Mon Aug 27, 2018 10:09 am
by Stephen Dean
From the information that I have, the Reference Mode is Multi Tooth Four Stroke, and it has twelve even teeth on the crank trigger.
Thu Aug 30, 2018 7:29 pm
by AlanB
Hi, we've run these bikes in BSB so have plenty of information.
Reference Mode = Crankshaft Two Missing Four Stroke
Tooth Count = 24
Reference Offset = 390.0 deg
Narrow Pitch Threshold = 50%
Wide Pitch Threshold = 180%
The engine syncs from a manifold pressure sensor connected to cylinder 1 (rear left as you sit on the bike), so you need to use the Engine Synchronisation Ignore function (try 1000rpm).
