M130 sensor ground query
I have a M130 in my car where the knock inputs currently are connected to two temp sensors and used as temperature measurements.
As I would like to install knock sensors on my engine and connect them to the appropriate inputs on the M130, I'll have to move the temp sensors. All my AI inputs on the M130 are already used, so I've aquired an E888 expansion unit and plan to move the two temp sensors there.
The two temp sensors are currently connected to sensor 0V-A on the M130.
I am questioning if it is advisable/possible to connect the sensor 0V-A on the M130 to the sensor 0V on the E888 to have a common sensor 0V.
I would like to do it this way if possible to avoid having to split up the existing wiring harness to add an aditional wire for the sensor 0V from the E888.
