About M1 Build Module
Postby junnan yue on Mon Aug 06, 2018 7:28 pm
Hi everyone
Yesterday I download an M130 GPR Project and do some modifications, everything good, no errors.
But today when I open up the project and this happened comes up! 244 errors!!! I think maybe because I have been changing something wrong, and I download the project again without any modifications open up and still the same thing! 244 errors! But the same project runs well on my other laptop with no errors.
No idea what I did wrong... ...
Please help me
junnan yue
Re: About M1 Build Module
Postby NBR on Tue Aug 07, 2018 9:43 am
Send a screenshot of the modules tab, im willing to guess that you have an invalid module in use within the project.
NBR
Postby Stephen Dean on Tue Aug 07, 2018 12:14 pm
As NBR stated, it appears that you are missing a number of Modules in the version of Build that you are getting the errors in.
If you go to C:\ProgramData\MoTeC\M1\Build\Modules you will see all of the modules installed on the system, you can copy the files from the computer that the Project builds on to the computer that it errors on (close M1 Tune first on both) to ensure that both are matching.
Postby junnan yue on Tue Aug 07, 2018 4:24 pm
Here is the screenshot of module.
And I did copy the file from another laptop, and makes no difference.
junnan yue
Postby Stephen Dean on Tue Aug 07, 2018 5:29 pm
Do you have M1 Tune installed on this computer? and is it the latest released version? If not, can you update it to the latest version and then do a check for updates. if it is the current version, can you please check for updates as well. There is a misalignment of the calibration repositories between some of the versions of Build and Tune that can also cause this issue.
Postby junnan yue on Wed Aug 08, 2018 6:42 pm
Yes. I do have M1 on this computer, and I did the check for update, all up to date. Still no different
junnan yue
Postby Stephen Dean on Thu Aug 09, 2018 11:20 am
We have found that there is an issue with the MoTeC Online file repository that is likely to be causing this issue. The engineers are working on fixing the issue at the moment and are planning on it being done later today.
Postby junnan yue on Thu Aug 09, 2018 3:29 pm
Thank you so much for your help SDean!
junnan yue
Postby junnan yue on Thu Aug 09, 2018 7:46 pm
All good now!!!
junnan yue
