M150 Current Draw
M150 Current Draw
Postby Rex-Racer on Mon Jul 09, 2018 12:16 pm
Trying to find the current draw of the ECU and can't seem to find that spec. Wanting to know if I can run the ECU off an 8amp PDM output or do I need to run it off a 20A output.
TIA
Jay
Rex-Racer
Re: M150 Current Draw
Postby Stephen Dean on Mon Jul 09, 2018 1:27 pm
Hi Jay,
The current draw of the M1 will vary dependant on the hardware attached to it, especially the number of DBW throttles used. The M150 with no inputs or outputs being used (essentially the M1 powered up on the bench) will have a no load current draw of 0.34A @ 13.8V.
The M150 (single DBW) that I have in my car is run off of a single 8A output on my PDM along with the C187 and LTC, and it peaks at around 5.5A. The Dash and LTC will draw most of that current as well.
The important wiring to have done on the M150 is the extra Battery Positive and Battery Negative pins on the A and B connectors, these must be wired if you are using the extra I/O on those connectors.
Postby Rex-Racer on Tue Jul 10, 2018 1:48 pm
That's exactly what I needed to know. Single DBW, Dash and 4 cylinder engine with one LTC so driving off the one 8A output is what I was hoping for, need the 20A for shifter air pump.
Good to know about the other power inputs needed, plan on using several I/O's.
Thx
Jay
Rex-Racer
Postby Herrubermensch on Sun Aug 12, 2018 9:26 am
SDean wrote:Hi Jay,
Wow! I have always connected two 20A PDM outputs to my M190s, running through all four BATT+ pins (single DBW, but all other half-bridge outputs used for BMW vanos control). Sounds like I am overdoing it quite a bit!
--Peter
Herrubermensch
Postby PEI330Ci on Tue Aug 14, 2018 2:48 am
Herrubermensch wrote:
SDean wrote:Hi Jay,
--Peter
Peter,
That is perfectly to scale with everything else in the car.
I wouldn't change anything on principle. :D
PEI330Ci
Postby Herrubermensch on Thu Aug 16, 2018 3:29 pm
SDean wrote:Hi Jay,
--Peter
Peter,
:D :D :D :D :D
Herrubermensch
