Nominating a MAF sensor as the Inlet MAP sensor
This might seem a bit weird but my application of an M130 is for a Subaru EJ253 in an aircraft and I will not be able to use the fourth (Ambient Pressure) axis to tune VE to minimum achievable ambient of around 50 kPa in advance.
Relatively small reductions in ambient of 96 to 88 kPa have seen increases in VE of about 7% at higher power so I expect to see substantial changes at normal operating levels around 8500' or 75 kPa.
It occurred to me that it might be possible to specify and calibrate my MAF sensor as the Inlet MAP sensor and this would provide an automatic method of establishing a proper position on the VE (fuel) table.
I attach an image of a log file which shows the close relationship between MAF and MAP although the former has a bit more resolution and is able to pick up on inlet cam adjustment problems. (see first WOT segment).
If anyone has any thoughts on the proposal I should be very grateful for them.
Rupert Clarke
Rupert Clarke
