M1 Wheel speed + vehicle speed settings
Hello all,
Need help again!
So we have migrated from M400 to M130 and I'm trying to figure out how to move the "vehicle speed" setting from M400 to M130.
In M400, we have the speedo sensor feed into the M400 dig-1 input and we use the calibration value in our case 375 to get close to the correct mph value.
It seems to be that M1 doesn't take such calibration value, I assume I may have to input the tires circumference value into M1 under "wheel" and M1 will automatically calculate it for us?
My current set up is
Wheel speed (FL, FR, RL, RR) all receiving speed information from ADL2 CAN bus.
We have entered the gear ratio (1-5 + reverse) as well as the final gear ratio into M1 tune in case this is needed as well.
I have configured the Wheel->rear->drive->source to the dig-3 inputs which read the hall sensor output from the transmission speedo sensor. What else do I need to do for the wheel->rear->drive to calculate the correct speed?
Cheers
Need help again!
Cheers
