Setting Up Automatic Engine Kill
I'm wondering how to set up an automatic engine kill based on coolant temperature. Ideally setting this up around 220 degrees Fahrenheit. Is there a way to do this? Ideally killing ignition.
I see the warning mode coolant temperature warning setting(does this correspond with the coolant temperature warning maximum and minimum values?) and I'm not sure if this will just pop up as a warning on the screen or how it works. Thanks!
