Hello All,
I'm hoping to gain more information about hooking up the Toyota OEM ABS speed sensors to the ADL2. I know for sure that the OEM speed sensor is a VR-Magnetic 2-wire sensors on all 4 wheels. I plan to splice them (all 4 pairs) close to the ABS module and wired them directly into the ADL2.
Question 1:
Do you see any potential problem splicing the ABS speed sensor signal close to the ABS module?
Question 2:
Does the ADL2 software has a oscilloscope screen (like the Ref Sync Capture screen in the Mx00 series) which I can test the sensor to make sure it is set up for rising or falling edge and the magnitude of the voltage when at driving speed?
Question 3:
Reading the ADL2 user manual, what does it mean by (Input Resistance : 100k ohms to groung (No Pullup)?
Thanks for the help all.
Cheers
