M1 GRP Water Injection Feature
Sun Jan 21, 2018 8:49 am
by SteveC
Just a quick one..
is it possible to get water/meth injection as a feature on the m1 to sit along side the water spray.
or does anyone have this working with all the values to make it work they can share ?
thanks
Steve
Re: M1 GRP Water Injection Feature
Wed Jan 24, 2018 2:25 pm
by PEI330Ci
I have both pre turbo and manifold injection, and I have done this 3 different ways so far:
Option 1:) Use one or 2 of the Generic Auxiliary outputs
Option 2.) Re-write the Auxilary outputs to define features exactly as you want with a development license
Option 3.) Write a complete stand-alone strategy with a development license
You can control flow control valves from Aquamist directly from the ECU, but you'll need to use an SSR if you are pulsing the pressure pump. (Not ideal in my opinion)
Attached is an example of Option 3
Fri Jan 26, 2018 2:29 pm
by MalcolmG
I think that
Water Injection Pre Turbo Injection Jets Jet 1 Jet 1 Flow Table is probably the longest name I've seen on any object in M1, and I really hope you've never had to type it all out to reference it from another group in Build
Sat Jan 27, 2018 2:44 am
by PEI330Ci
MalcolmG wrote:I think that
It is referenced, but it's a lot easier when you're using functions inside of that tree.
