Wiring a engine kill/isolator with M150
Hi There
I'm looking at a Cartek XR battery isolator/kill switch and wanted some guidance on how to connect to the M150. The XR has high-current MOSFET to isolate the battery from chassis ground and sends a +12v output designed for connection to the ECU as an 'enable' signal. If this signal is cut it relies on the ECU to kill the engine.
Where would I wire this 12V enable signal on the M150? My understanding is +12v engine should run, 0V engine should stop.
The car is a Toyota 86 with M150 and Motec adaptor loom. There is lots of OEM wiring etc I'd prefer not yo hack.
