Gearbox reverse lockout Solenoid
Sun Jan 07, 2018 12:42 pm
by TUF-427
M130GPA, What’s the best way to implement a speed based reverse lockout solenoid, T56 and the like
Relay can only be energized when vehicle speed is zero.
Previously I’ve set these up as a brake pedal press supplying the 12v and Ecu seed based ground for relay activation.
Re: Gearbox reverse lockout Solenoid
Mon Jan 08, 2018 9:57 am
by MarkMc
If it is just an activation based on vehicle speed then we normally just use the Coolant Fan functions, there is 2 separate Coolant Fan functions available. Just set the temperature to low enough so the temperature activation is always on. The vehicle speed is the speed it must be below to activate, I would suggest something non-zero but very low like 1-2km/hr.
Mon Jan 08, 2018 6:18 pm
by TUF-427
MarkMc wrote:Hello,
Cheers thanks for that Mark, car only has one thermo fan so that will work well.
Regards
