8 Throttles V8 Ford setup for M130
Hi all doing a wiring and base setting install for an 8tb V8 Ford and have some Qs,
My First Motec install, and Ecu is an M130GPA , E888 for pyros , CDL3 and Wideband.
Intake has a plenum under so generally in my Autronic fitments would cross throttle Map,
Fuel being Throttle position Vs Rpm and timing derived from load vs rpm, using the map sensor.
Watched the first webinar and it seems the M1 series has some more complex choices here,
Anyone shed more light here, customer supplied 1 Bar Map but is Baro just derived?
