Data logging
Fri Nov 17, 2017 9:18 am
by greenamex2
Hi all
Is there any way of persuading the GPA to start datalogging without an RPM signal?
Re: Data logging
Fri Nov 17, 2017 9:45 am
by David Ferguson
If you look in Tools->Edit Data Logging, you will likely find that logging is started when the Logging Request channel is true. If you look at the help for "Logging Request", you will find that it says:
Data logging will start when either:
•Logging Engine Speed is greater than 0 and Engine Speed is greater than Logging Engine Speed.
•Engine Speed Reference State is not Stall.
•Logging Throttle Pedal is greater than 0 and Throttle Pedal is greater than Logging Throttle Pedal.
Hopefully one of those will work for you, or perhaps you can use another channel for the logging condition (particularly if you have level 2 logging enabled).
Now, normally I would just use the strip charts in M1 Tune. Hit the pause "T", then scroll back, change screens, to view all the channels (not just the ones in the Normal Log).
Re: Data logging
Tue Nov 21, 2017 8:35 am
by greenamex2
Thanks David, I have rigged the throttle pedal for the moment
