engine speed/ sync ref.pin setting
I'm using a M130 with the 2012 superbike package on a 2009 Honda CBR1000 RR.
I want to prepare it for dyno runs, to have a proper mapping. I'm now trying to figure out the right engine speed and sync ref. pin setting. I started to crank the engine with engine speed pin set to "falling edge" and the sync ref. pin to "rising edge". The engine started, but only with a shot of brake disc cleaner, and could not hold idle, missfiring a lot and put a lot of flames out of the exhaust, and was not willing to reving up, overall sounds absolut not healthy. The "Ref Sync Status" windows shows a lot of errors too. I made some scope screenshots and send it over to the support in UK. Meanwhile I changed the engine speed pin to rising edge, and after that, the engine starts, could hold idle after a while, and revs up with a little delay. After the UK support saw my scope pictures they told me to switch the engine speed pin back to falling edge, with the result that the engine runs like crap. So I played around and set the engine speed pin to rising edge, and the sync ref. pin to falling edge. What a change. Engine starts without any additional help of high flammable sprays or giving some throttle. Just push the start button and it idles. Also reving the engine works without missfire and flames. "Ref sync status" window shows no errors, for me everything looks good. I know had a look on the initial package that I first received, and there was exactly the same setting for both pins like I have now. I don't know why and who changed my initial setting, but over the time and sending the package back and forth somehow it was changed. So can someone tell my if it is ok to leave it like it is now, which is matching the initial setting, or what should i do!?
Actual --> engine speed pin (crankshaft signal) rising edge
--> sync.ref. pin (crankshaft signal) falling edge
Thanks in advance,
Mike
Thanks in advance,
Mike
