Fuel Used M1
Hi Guys,
I am trying to work out how this is calculated as I am getting some inconsistent readings.
The channel (Fuel Used M1) when logged in i2 shows in (ml) and seems to be a raw value from the M1. After doing some testing at the track it seems the value it returns is not very accurate or consistent from session to session.
I confirmed this by doing some manual testing. i.e. completely drain system, put in exact 20lt of fuel, run session, drain tank completely and calculate fuel used.
When compared to the Fuel Used M1 reading I could not get a consistent read. I was hoping to at least find a consistent difference % so that I could adjust using the fuel usage math in the dash logger.
For example:
Session 1 - M1 channel says I used 23.8lt when I manually calculated 16.5lt. Difference = -69%
Session 2 - M1 channel says I used 21.3lt when I manually calculated 11.9lt. Difference = -55%
Session 3 - M1 channel says I used 9.1lt when I manually calculated 10.8. Difference = +16%
Session 4 - M1 channel says I used 10.8lt when I manually calculated 11lt. Difference = +2%
Any ideas why the results would be so inconsistent?
Cheers,
Trevan
For example:
Cheers,
Trevan
