Shift Kill elimination when using an 1-2-3 AUTO TRANS
Postby tcaldwellps9 on Wed Aug 30, 2017 6:26 am
Ok, when changing from a ignition kill-shift type motorcycle transmission and going to a 1-2-3 AUTO TRANS (NOT AUTO SHIFT), where do you shut off the ignition kill on the 1-2-3 shifts?
tcaldwellps9
Re: Shift Kill elimination when using an 1-2-3 AUTO TRANS
Postby Stephen Dean on Wed Aug 30, 2017 10:38 am
if Gear Shift Mode is set to Not in Use then the shift cut function is disabled.
Postby tcaldwellps9 on Thu Aug 31, 2017 1:28 am
I only want the ignition kill blocked in the first 3 gears and not 4th an 5th. No in all gears.
tcaldwellps9
Postby Stephen Dean on Thu Aug 31, 2017 10:42 am
Sorry, I didn't realise that there was more than the three gears mentioned. In this case you can set the timings for the first three gears to 0 in the Gear Shift Timing table, and there will not be any cut applied.
Postby tcaldwellps9 on Thu Aug 31, 2017 10:31 pm
MoTc Shift Kill.JPG (68.99 KiB) Viewed 13875 times
Here right?
0 all cells for 1st, 2nd and 3rd.
tcaldwellps9
Postby Stephen Dean on Wed Sep 06, 2017 2:15 pm
Apologies for the late reply, I didn't get a notification of your reply and it didn't show up as a new post.
That is correct, setting those values to 0 will deactivate the function in those gears.
