idle to high
Tue Aug 29, 2017 12:36 am
by nwwil
i can not get my car to idle any lower than 2000 rpm, useing a ford falcon turbo fbw and m150
Re: idle too high
Tue Aug 29, 2017 2:52 am
by David Ferguson
Is this a new problem, or a new installation?
So many questions... -- could you post your configuration and a log from the engine running?
Re: idle to high
Tue Aug 29, 2017 3:45 am
by nwwil
a new insulation
Re: idle too high
Tue Aug 29, 2017 9:03 am
by David Ferguson
Things that control whether the idle system is active:
Do you have Idle Mode enabled (Tune->Engine Systems->Idle Aim Idle Setup Panel)?
What are the values in the Idle Aim Main table?
What is the value of Idle Activate Engine Speed Margin?
What is the value of Idle Activate Throttle Pedal Threshold?
Things that control the Throttle Aim:
What is the Throttle Position when the engine is idling at 2000 RPM?
What is the value of Idle Actuator Throttle Aim?
What does the table Idle Mass Flow Feed Forward look like?
What are the values for Idle Mass Flow Proportional Gain, and all the Idle Mass Flow Integral XXX parameters.
Re: idle to high
Tue Aug 29, 2017 9:05 am
by Stephen Dean
As David said, Can you please post logging (preferred) or the M1 Package thanks.
